$1200 Cabela's Gift Card For Sale- Louisville, KY
by FirstNissan
08/28/16 08:37 PM
Motor oil recommendations, '04 Toyota Sequoia
by ShadowSix
08/28/16 08:21 PM
Quick Question About Car Battery Quality And Price
by crazyoildude
08/28/16 07:44 PM
Shelf Life of Gas Stabilizer.
by George7941
08/28/16 07:34 PM
Got some Leather Seats for the Focus
by Miller88
08/28/16 06:53 PM
Ford's take on leather care
by buck91
08/28/16 06:45 PM
nissan and a dodge
by mobilaltima
08/28/16 06:25 PM
Adding LED lights to a lawn tractor
by sciphi
08/28/16 06:22 PM
Pet protection
by buck91
08/28/16 06:18 PM
Sam's club "certified motor oil"
by TmanP
08/28/16 06:18 PM
Ford 6F55 transmission
by buck91
08/28/16 06:16 PM
BMW 0W-20
by jdavis
08/28/16 06:09 PM
turrican, GGilbert, leje0306, DLL, Mazdapremacy
58950 Registered Users
120 registered (ag_ghost, 69GTX, 4WD, 123Saab, addyguy, 2015_PSD, 14 invisible), 1614 Guests and 6 Spiders online.
58950 Members
66 Forums
253693 Topics
#3127157 - 09/17/13 12:58 AM Why hesitation when radiator is low
TechnoLoGs Offline
Loc: Call it NNJ
Why do cars and trucks hesitate on acceleration when low on coolant, or if there is air in the system?
#3127163 - 09/17/13 01:17 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
TechnoLoGs Offline
Loc: Call it NNJ
*Additional: also, as for mine, I cannot figure intended use of the red lever on radiator cap, as to pressure, how it works, what it does, its intended purpose, or what.
Been trying to bleed and flush my system offa DexClone, is 100% water now... wanting it to run clear from lower hose before 50/50 Ethylene Glycol green/water.
1993 Chevrolet S-10 Blazer 4.3, the Frankenblazer - 184,440mi. 10/22/13 - WPP Supertech 10W-40
12,359 10/22 12,361 10/23 12,365 10/24 12,369 10/25
#3127204 - 09/17/13 05:33 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
yonyon Offline
Loc: NJ, USA
The truck didn't come with that cap. The red lever allows you to vent pressure with less risk of being scalded if you do it wrong. Lift the lever to allow venting and if you hear boiling you can smack it back down.
Generally they don't. Some are programmed with overheat protection in the computer, but your Blazer doesn't have that. If you're getting the heads so hot that it runs badly you're probably causing damage. Stop doing that.
#3127207 - 09/17/13 05:39 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
Falken Offline
Loc: Montreal, QC, Canada
If it is running hot it is running lean, so it injects more fuel and doesn't advance timing as much. Also, running hot leads to pre ignition.
Also, if it starts to knock in most cars a knock sensor will retard timing and inject more fuel.
All this to try an prevent you from destroying your engine... But, some people will run a car without coolant and a new engine or new vehicle is inevitable.
Falken - Draftsperson
2010 Honda Fit DX-A in Black
Current Fill: Formula 1 Synthetic 5W20 SN, Wix 57356 Oil Filter, ATF DW-1
#3127210 - 09/17/13 05:52 AM Re: Why hesitation when radiator is low [Re: yonyon]
TechnoLoGs Offline
Loc: Call it NNJ
Putting antifreeze in now.
Would you all advise I keep of replace the cap?
#3127228 - 09/17/13 06:37 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
TechnoLoGs Offline
Loc: Call it NNJ
K I have 1 gal. Ethylene Glycol in, getting level adjusted with water. Distilled.
#3127256 - 09/17/13 07:29 AM Re: Why hesitation when radiator is low [Re: yonyon]
TechnoLoGs Offline
Loc: Call it NNJ
I thought air in the system caused the hesitation. I did not have level full until recently.
The hot heads may have gotten a risky steam-cleaning, but I put in 1 gallon Ethylene Glycol antifreeze and the engine is cooling now to top off with 1gal. distilled water.
I almost feel like that cap messes up the level AND releases the system of air when you raise it.
#3127383 - 09/17/13 09:48 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
951Indy Offline
Loc: Indy
I'd leave the red lever alone. Fill the system, including reservoir. Take it for a drive. After it cools, check the reservoir and add if needed.
Your hesitation problem will need addressed after that.
#3127409 - 09/17/13 10:22 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
AVB Offline
Loc: Georgia
Are you sure the hesitation isn't related to the spark plugs you just replaced?
#3127427 - 09/17/13 10:35 AM Re: Why hesitation when radiator is low [Re: AVB]
TechnoLoGs Offline
Loc: Call it NNJ
I don't know enough mechanically to answer that question, or even how it could be. Went from Autolite to AC Delco CR43TS.. The hesitation is lessened.
I actually think my coil is loose. I will show why in a moment.
Think the new plugs "awakened" something?
And FWIW: I have had a few cars "low on coolant." They all ran rough to some degree. Then topping off a "Thirsty radiator" it ran smooth...
I kinda think running with water only made the water pump unlubricated and now that the antifreeze in 50% concentration 40% at the minimum, it will re-lubricate????? WAG.
But the Taurus had a binding water pump... that had been ran with just water, tons of rust came out. before coolant, then it ran fine when the proper mix was in..
#3127428 - 09/17/13 10:36 AM Re: Why hesitation when radiator is low [Re: 951Indy]
TechnoLoGs Offline
Loc: Call it NNJ
At this time, I have the water out of reservoir, am filling to top of cap, looking to make sure no bubbles (I never see any) and THEN add coolant mix to reservoir after shut-off, leaving red lever down.
Yes?
#3128310 - 09/18/13 07:10 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
951Indy Offline
Loc: Indy
"including reservoir"
#3128368 - 09/18/13 08:26 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
TechnoLoGs Offline
Loc: Call it NNJ
UPDATE! Turns out: Transmission fluid may be low due to a leaking transmission cooler.
This may have caused my "hesitation" as engine power (smooth) = transmitted to trans (low, maybe a quart hot.)
I wonder what all is involved to replace/change that. It's not gushing, but some drops can be seen if I let it idle for about 15 minutes or longer. Not sure if it drips when I shut it off. Depends on time and if full hot, I guess.
#3128369 - 09/18/13 08:27 AM Re: Why hesitation when radiator is low [Re: TechnoLoGs]
TechnoLoGs Offline
Loc: Call it NNJ
I've still had cars hesitate/run roughly when the radiator was low. They then ran perfect after their radiator had coolant added until the system was full. (Either via cap or tank, depending the car.)
