Long story made short, the dealer used the wrong screws to secure the license plate to the front bracket and won't own up to it. Therefore, the holes that they created in the bracket are too wide and the correct hardware now doesn't work.
Factory self-tapping screw: 1/2" L x 1/8" D
Dealer's [censored] screw: 3/4" L x 1/4" D
Is there a way to "plug" the existing hole and then let the correct screws re-tap it? New bracket is $50 and comes unpainted. Otherwise I need to find very short but fat self-tapping screws, which may not even exist. I suppose I could always use a bolt and nut on the back, but that's going to look pretty stupid. I would prefer they be stainless so they don't rust in a month.
Top picture is the enlarged/damaged hole. Bottom picture is what it should look like. Black screw is the OEM hardware, silver is the idiot dealer's choice.
