I'm going to go OT for a second, and recommend that you check the following on this car:
1. Chassis: lower torque mount on the transmission, upper engine mount and front lower control arm bushings. All fail relatively quickly on the Volvo P2 chassis.
2. PCV: You should check the PCV system...on a Volvo they're called "Flame Trap"...and if the PO didn't change the oil often enough (let the TBN get low) they sludge/plug up quickly....this leads to oil leaks that become very expensive to fix.
3. Oil: Volvo specs an ACEA A1 oil in this, but there is a TNN on sludged "white block" motors that requires an A3/A4 after the sludge is cleaned out. I would use a good extended drain A3/A4 oil...M1 0W40 is a great choice, so is the Pennzoil Ultra that's in my XC at the moment...it says 5W30 in the OM, but then goes on to say that a synthetic is recommended for severe use and a 5W40 is recommended in high temperatures...so you've got a wide range of choices in viscosity, but use an extended drain oil...
4. Timing belt: it's an interference engine, interval should be 105,000 miles on your year...make sure it gets done on schedule.
