I cut open filters all the time and frequently on one OCI see very little light when the pleats are pulled out and stretched flat and held up to a lamp. I won't run them multiple OCIs.
If you run a screw into one of the input holes then drain the filter out that low spot for a while, it should have less oil to spill out when you cut it open. Today I changed the oil on a 1997 Escort cold, it had sat all night. I drained the filter and when I cut it open, no oil came out the cut, and it was quite well drained considering it was drained cold, not hot.
