2002 Windstar, 146k on the clock. I've been chasing an intermittent misfire for a month or two. I've eliminated all of the usual (easy) suspects - plugs / wires / coil pack / vacuum leaks / EGR etc.
Just did a compression test, results are
#1 140
#2 140
#3 142
#4 140
#5 165
#6 80
What do you guys think - is it worth fixing?
I guess the next step is pull the head and look at the valves and gasket to try to find the problem? Or should I be pulling the engine and looking for a new one?
#1 140
#2 140
#3 142
#4 140
#5 165
#6 80
