Finally got the ole lebaron replaced. My new to me mountaineer is great so far, except every now and then, it wont shift out of park unless i bounce up in down in my seat and shake the truck until it finally moves with little effort. I only figured that out because my dad was with me the first time it happened.
He said his 81 flatbed ford does it if its under heavy load. I was hauling about 400 lbs of quick set cement first time it happened.Now it does it when its just me in the vehicle, parked flat, uphill, downhill, no pattern except AC is on when i shut it off, but that shouldnt matter
Dealership i bought it from looked at it and couldnt duplicate the problem.
I disabled the shift interlock, checked the brake lights to make sure they were working, supposedly theres a sensor in the braking system that locks the transmission in park until the brakes are pressed. ive not found anything solid doing a google search. Transmission was replaced 5k before trading into dealership , was provided Documentation.
I know it sounds petty, but i feel dumb bouncing up in down in my truck in the parking lot at walmart
Thanks in advance
Thanks in advance
