Morning All,
I am getting ready to do some scheduled maintenance on my 09 Mercury Mariner with the v6/3.0L engine. According to what I have read, because I commute only a few miles to work and sometimes do some fast accelerations due to my being a firefighter and responding to calls, I should be following the Extreme Driving/Hauling maintenance schedule. I have 60,000 miles on the vehicle and just replaced the brakes. (I'm the original owner) I put about 15,000 miles on the vehicle a year and like to take care of as much of the vehicle myself as is possible. I am looking to replace/do the following and wondering if anyone has any suggestions on parts, intervals, additional maintenance, etc.
- Flush Radiator Fluid (Planning to use Zerex G-05 Gold, at least 1 flush with RO water, then refill 50/50)
- Replace the Spark Plugs (Suggestions on what kind of purchase?)
- Bleed/Replace Brake Fluid
- Replace Air Filter
- I am told the fuel filter is part of the pump. Is this replaceable, or only if I need a new pump?
- ATF Flush. I will most likely use (Amsoil Synthetic Fuel Efficient Automatic Transmission Fluid)
Does anyone have any other suggestions as to what I should replace or service? Is so, what parts or brands should I use? Thanks for the suggestions.
Joe
Joe
