Hello,
I've got a 2012 GMC Sierra Denali that I've had converted to run on CNG (can switch back to gasoline too), and I'm wondering what oil and filter people would recommend. It has 15,000 miles and the oil change light just came on, so it's time for its second oil change now. I drive about 3,000-3,500 miles per month, mostly highway. I don't have a lead foot but I drive harder than some. I installed a Volant air intake with the nicer air filter option, it's supposed to be a higher quality filter. Also I live in Houston, TX, so cold isn't much of an issue but it gets plenty hot.
I intend to drive this truck for quite a while and would like to run a good oil, but I don't want to waste money on oil change more often than necessary or on synthetic oil if conventional is just as good.
People seem to think that the CNG will extend the life of the oil because it doesn't get contaminated as much, but it seems it would still break down just as quick. Just to get the conversation started, I'm considering going with Mobil 1 synthetic and the Mobil 1 filter, and going 2x the regular recommended interval, meaning I would reset the light once and then change oil next time it comes on, which would be about 15,000 miles.
Any suggestions and advice is greatly appreciated. Thank you in advance.
