Originally Posted By: neilLB7
Brake fluid absorbs alot of moisture. That's its job in part. So it's VERY worthwhile to remove/replace it as often as practical. I use a Vaccula air powered vacuum bleeder. Makes it simple and pumping the brakes isn't required (on most vehicles).
Be cautious of draining a system dry. On some ABS pumps...it's possible to get air in them. And impossible to get it out without forcing the pump to run with a laptop plugged in. Most ABS pumps test run on every start up...but it could take hours to get the air out this way. Most pumps remain sealed (or closed tight) during bleeding...so some old fluid remains after bleeding but not enough to worry about for me.
Using vacuum bleeding never drains the system to allow air in unless you forget to keep the reservoir topped off during.
Brake fluid is the often forgotten fluid that never gets changed by most owners. That and power steering fluid (for vehicles that still use it). Your lines can rust from the inside out...and rust particles are BAD on components before that.
Why would anyone bleed a working system dry?
You can remove the lines if you want, I would depress the brake pedal an inch or two, supposedly this prevent the MC from completely draining. If you don't, you have a few minutes to get the line back on before problems (emptying the MC) happen.
A few years ago, my friend did a caliper swap on an explorer and left the line for hours, and lost fluid very slowly, so they just kept topping up the MC until it was done.
There is only two ways to bleed the system: pressure bleed and manual pump by the foot.
