Originally Posted By: JimPghPA
BTW, the final oil viscosity of a mix is not a linear average of the oils used to make the mix, but it does end up being something between the thickest, and the thinnest, and is is weighed in the direction of the linear average. Such as if you put 4 quarts of 10W with 1 quart of 30W the final would be thicker than 10W and thinner than 30W, and closer to the 10W than it would be to the 30W.
That's why it's always best to mix 0W-XX oils with other 0W-XX oils, 5W-XX with 5W-XX etc if you are concerned about retaining your XW rating. But at non extreme temp's using a viscosity calculator works quite well. Ultimately it helps to have an oil pressure gauge to judge the operational viscosity affect of any
mix.
