This is actually the second time on BITOG i've asked for help in removing something related to brakes, this time it's the rear drum on a 2000 Ford Focus SE. It has a 30mm bolt that holds it on, which is part of the bearing, I suppose. I took that off, came off ok, but the drum will only move about 1/4 of an inch. It doesn't seem to have a retractor on the back. I've pounded on this thing forever, and it doesn't want to come off. Any advice on removing stuck rear brake drums?
Also, in this case, there is no little hole on the drum to put a bolt through, and the wheel studs are part of the drum.
