OVERKILL
$100 Site Donor 2021
Originally Posted By: FoxS
Here's a link where XOM state that the higher VI leads to reduced wear.
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=695007
They made it the first point in the first slide so it must be the most important one
The next most important thing is low temp properties, again for reduced wear
According to XOM, Volatility is related to oil consumption not directly to wear
That's a great presentation, but keep in mind they are also comparing it to conventional oil.
I didn't reply to the other post where you replied to me, because in general, we are mostly in agreement, however I do believe we need to touch on the "all things being equal" statement, because all things can't be equal, as lubricants are a compromise. As per the discussion with CATERHAM, to get these ultra high VI's, you need to use more polymer, as the native VI of the synthetic basestocks and the AW package is only going to get it so high. This is where the issue of shear comes into play, as even though, as CATERHAM mentioned, the newer VII's are more shear resistant, his experience with these lubricants shows that they do very quickly shear notably in use before stabilizing.
This of course isn't factored into the presentation.
And this is also where that convenient adage "As thin as possible, as thick as necessary" comes into play again. As long as the amount the oil shears is acceptable for the application, you benefit from the higher VI and more consistent lubricant performance during the temperature swing. However, if the level of shear is not acceptable for the application, then while cold temperature performance is increased, hot performance is compromised.
I am confident that this is the reason XOM doesn't have VI's of 200+ even in their AFE lineup. Because the lubricant needs to be acceptable for use in a wide range of applications, including the Ford one we've noted, whilst the Toyota lubricant, designed and tested for Toyota, does not
