Oil Changer: I'm sorry to hear of your mis-fortune. Transmission replacement is a hard pill to swallow regardless of who you are or your station in life.
I am curious, though, how you collected the sample that you sent to Valvoline. They said that there was zinc in the fluid; this does surprise me. I've done what I could consider an above-average amount of research on various ATFs and the only fluid of which I'm aware that uses zinc is Honda brand ATF. Both the Honda Z1 and DW-1 contain significant concentrations (for ATFs) of zinc...nearly 300 ppm.
Indeed, Valvoline's MaxLife ATF, like every Dexron III type ATF I've seen, contains no zinc. I am curious about the source of the zinc in your sample. Did you collect the sample from the transmission pan, or maybe from your engine oil drain pan? I'm wondering if there was some cross-contamination going on there.
