Anyone here gotten late life orthodontics?
by LoneRanger
08/29/16 12:30 PM
iPhone Touch Disease
by Pop_Rivit
08/29/16 11:22 AM
Windows RUN (tool) troubleshoot
by Triple_Se7en
08/29/16 10:58 AM
Spark plug gaps
by SpeedyG75VW
08/29/16 10:27 AM
Funny Craigslist ad
by Drew99GT
08/29/16 10:23 AM
Formula Shell dino
by Camprunner
08/29/16 10:05 AM
Linux Distro for laptop
by LeakySeals
08/29/16 09:24 AM
GM Pickup Trucks With G-80 Locker Read This
by Silverado12
08/29/16 09:12 AM
M1 EP 0w20, 12764 mi oci, 50302 mi 2013 RAV4
by SF0059
08/29/16 08:25 AM
AC blows dead animal smell with a huge vibration!
by puredata
08/29/16 08:04 AM
Oil consumption early vs. late in OCI
by skaughtz
08/29/16 08:03 AM
Kaepernick disses national anthem
by grampi
08/29/16 07:19 AM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
103 registered (901Memphis, 74Scout, 1JZ_E46, Al, 87sammy, AirgunSavant, 6 invisible), 1779 Guests and 8 Spiders online.
58952 Members
66 Forums
253721 Topics
Page 1 of 2 1 2 >
#2853898 - 12/31/12 04:35 PM Duece and a half
ridgerunner Offline
Loc: PA
I've seen that diesel military vehicles, like the old deuce and a half, can run on old motor oil. What makes them able to do this where our diesels can't?
#2853934 - 12/31/12 04:59 PM Re: Duece and a half [Re: ridgerunner]
Kuato Offline
Loc: In transit...
Emissions. Even the mid-90s Dodge Cummins could use fry oil, used motor oil, heating oil, whatever you cared to pour into it (filtered for chunks of course)
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#2853935 - 12/31/12 04:59 PM Re: Duece and a half [Re: ridgerunner]
motor_oil_madman Offline
Loc: Houston, Texas
cause they are old engines that aren't built to the tight tolerances of the engines of today.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2853936 - 12/31/12 05:01 PM Re: Duece and a half [Re: ridgerunner]
bigjl Offline
Loc: London, England
Diesels will run on pretty much any kind of oil, the reasons I think are military vehicles still run on it is quite simply they are engineered that way.
For example the 1.9 XUD engine as fitted to many Citreons and Peugeots could run on pretty much anything, engine oil, used engine oil, used cooking oil(filtered) and virgin cooking oil not forgetting biodiesel.
Why could it do this?
Because the Bosch diesel pump was not reliant on the fuel for lubrication, but relied on the engine oil.
Any diesel will run on used oil, bio or cooking oil, just that due to lack of lubrication or simply being too thick for the pump to flow when cold the lump would suffer. Hence why people have twin tank systems that start on normal diesel and then have a seperate tank for cooking oil either used or virgin, I think they are heated aswell.
If you check I think you will find the diesel pumps are also lubricated by the engine oil.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#2853946 - 12/31/12 05:09 PM Re: Duece and a half [Re: ridgerunner]
DrDusty86 Offline
Loc: TX
Check out the CP4 injector pump that the Duramax, PSD and VW TDI use. The failure rates are insanely high. This is with "filtered diesel" it costs the Fords 12k + for a repair of a CP4. When it goes it TRASHES the fuel system. tighter tolerances maybe combined with SUPER poor build quality of the fuel systems for the NA market.
Bosh has admitted they never built the CP4 to run on NA diesel fuel. why the heck would you let a company fit it to a vehicle being sold here then????
The 6.9/7.3 IDI and the 12V would run on darn near anything.
Emissions SUCKs..
if a 6.0L gets 20mpg and a 6.4 gets 10mpg WHILE producing half the emissions and making it so friggen complex. WHY THE HECK are they waisting the time.
They are cutting costs to increase profit margins at the expense of the owners. Heck, I'm looking at a Dodge just for the stick shift and CP3 puke puke puke and Dodge's build quality is horrific
Edited by DrDusty86 (12/31/12 05:15 PM)
#2854014 - 12/31/12 05:58 PM Re: Duece and a half [Re: ridgerunner]
05Blazer Offline
Loc: Illinois
Kuato,
What cummins engines do you speak of and what years? ARe you referring to 94-98 5.9L 12Valves?
12 GMC Yukon SLT 4WD 5.3L 8K
Mobil1 EP 5W30 AC DELCO PF48
11 Honda Pilot EX 4WD 3.5L 20k
Penn Plat 0W20 OEM filter
#2854058 - 12/31/12 06:41 PM Re: Duece and a half [Re: ridgerunner]
Shannow Offline
Loc: Oz
As a broad generalisation, if you have an in-line pump, like so many disels used to have, they can run on nearly anything that fits in the tank. Bosch rebuild procedure was to fill IP with SAE 30 after a rebuild.
A rotary pump, without viscosity control (heating) is simply asking for trouble, and even with viscosity control is still asking for trouble.
#2854080 - 12/31/12 07:06 PM Re: Duece and a half [Re: Shannow]
ridgerunner Offline
Loc: PA
So let's say that I'm looking for one of these older diesels. Where would U steer me? 5.9 Cummins? What yr? What else could I do to it to make sure it would work on the ocasional dose of old, filtered engine oil, etc?
#2854174 - 12/31/12 09:07 PM Re: Duece and a half [Re: ridgerunner]
bullwinkle Offline
Loc: Cincinnati, OH, USA
You would want the P-pump Cummins, or the inline IP used on older Mercedes IDI diesels, like my '82 300D. Contrary to what some say, I would be hesitant to run any old oil in a Stanadyne rotary (Ford/IH 6.9/7.3 IDI, GM 6.2/early 6.5) or Bosch VE (early Cummins Ram) or VP pump-they can still be easily damaged by water or junk in the fuel. Don't forget, fuel dilution of your oil or even jamming of piston rings can result from non-diesel oil that doesn't completely burn in the combustion chamber-that's why biodiesel is processed.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#2854686 - 01/01/13 12:15 PM Re: Duece and a half [Re: 05Blazer]
Kuato Offline
Loc: In transit...
Originally Posted By: 05Blazer
Kuato,
I knew a guy that had a '93 Cummins Dodge. He had put used oil and vegetable oil in it and not had an issue, except I think lower mpg with the veggie oil.
Check this: https://www.youtube.com/watch?v=TAxw2HG70g4
I also knew a guy that ran his 80s MB diesel on jet fuel. (he was a mechanic and got the fuel for free.)
Edited by Kuato (01/01/13 12:15 PM)
#2854710 - 01/01/13 12:40 PM Re: Duece and a half [Re: ridgerunner]
Spazdog Offline
Loc: Arlington
you can run MoGas in a Duece and a Half.
You had to add motor oil in to lube the injector pump. I forgot the ratio. It was a fairly significant amount.
Kerosene, JP8....didn't matter. I'm sure we could have used the grease from the fryers at the Mess Hall (DFAC for you young troopers). It probably wouldn't have run very well but they didn't run that great anyway.
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
#2856785 - 01/03/13 10:24 AM Re: Duece and a half [Re: Spazdog]
HerrStig Online   content
Loc: Boston, MA
Obviously when somebody's waiting for ammo, the emission profile of the vehicle carrying it is secondary.
#2859459 - 01/05/13 04:48 PM Re: Duece and a half [Re: ridgerunner]
Silk Offline
Loc: New Zealand
There were some trucks, Mack I think, that used to cycle engine oil into the fuel tank and replenish the sump from a remote tank...a continuous oil change. The Mitsubishi 4M40 has a gear driven rotary pump, the lift pump is in the front of a VE pump, and instead of diesel leaking into the sump as you'd expect, the pump sucks engine oil into the fuel system. You know you have this problem when the fuel filter is black from engine oil. There are starting problems because a small amount of fuel drains from the lift pump, but the engine runs fine on black fuel.
1994 Mercedes C220 - Penrite Advantage 10/40
1987 BMW R65 - Penrite 20/50
2005 Nissan Expert - MSL 5/30
1996 Volvo T5 - Magnatec diesel 5W-40
#2933893 - 03/09/13 08:11 PM Re: Duece and a half [Re: ridgerunner]
morris Offline
Loc: ks, wichita
when i was in the USA Army in the mid 70s. our old deuce and a half was a mulita-fuel engine, would run on, all diesel fuel, a mix of diesel/gas, or gasoline stright. but my 5 ton wrecker was a straight diesel.
#3066261 - 07/15/13 04:39 PM Re: Duece and a half [Re: ridgerunner]
2cool Offline
Loc: Delaware
I was a 63B Light motor vehicle mechanic in the Army. The engine in the olde 2 1/2 truck was a MAN design built under license by engine companies such as Continental, Hercules, and Mack. The fuel pump has a fuel-density compensator (FDC) on the end of the pump where the fuel line is fastened. Basically, the FDC "weighs" the fuel coming in and adjusts the injection timing. The operating theory is that denser fuel will burn more slowly, so the injection timing is longer to get through the injectors. If you use gasoline or similar (and it WOULD burn alcohol, paint thinner, solvents, literally anything that would take fire from a match), mix 1 QT of SAE 10 oil to 25 gallons to lubricate the pump.
FWIW, all of the land forces are now on one fuel to make supply simpler; and I believe it's JP8.
Page 1 of 2 1 2 >
