So basically I bought a 2001 AWD 4.7L Durango from my father-in-law. I have a service record spreadsheet that I made up from his receipts and it came up that the transfer case needed to be drained and filled. According to the owners manual the TC needs ATF+4 transmission fluid. I crawl under the Durango and almost break an T wrench undoing the plug only to find instead of the unique odor and thin viscosity of ATF+4 greeting me the thick viscosity and sulfur odor of a gear lube, probably based on looks a 75w-90. Needless to say I am suprised and a little concerned. i contacted teh dealer who did this and here is their response--
THE FLUID THAT WAS USED WHEN WE CHANGED IT WAS A BG PRODUCT CALLED SYNCRO SHIFT SYNTHETIC TRANSFER CASE FLUID (WHICH WE SELL IN OUR PARTS DEPARTMENT ) FROM THE FACTORY IT HAS ATF.
SO IN ANSWER TO YOUR QUESTION YOU CAN USE EITHER BUT FROM MY TECHNICIANS OPINION IS IT WAS CHANGED TO SYTHETIC SO HE WOULD RECOMMEND STICKING WITH SYNTHETIC.
THANK YOU
I am a little [censored] off that the dealer felt it was ok to put gear lube in a TC that called for ATF. The fluid has been in there for almost 25K miles with no "apparent" issues. What would you'all do if you were me?
Thanks, Ben.
THANK YOU
Thanks, Ben.
