Soooo, I'm not the only one who uses Fuel System Cleaner(FSC) and gets a CEL.
My wifes '01 Lexus RX-300 seems to throw a CEL apon the use of a FSC(at the regular doseage) and deffinately DOES NOT like MMO.
I can use FSC's in her 1MZFE(Toyota 3.0L V6) engine but at just shy of the normal doseage and deffinately NO OVERDOSING!
When the CEL apears, the enging still runs fine, it's just throwing a Code pertaining to the A/F sensor on one of the Banks.
I have not had to replace the O2 sensors due to the FSC, just another tankfull of gas w/o FSC and all is OK again!
Yes, I have replaced the O2 and A/F sensors over time as the CEL wouldn't go away...This may be due the the FSC but, I can't answer if FSC's(Regane/Techron) were the culprit over the years. I did replace the A/F sensors kind'a prematurley but, the A/F sensors for this RX-300 shows up in the frequency of repair ratings/trouble spots. So, IDK!
And yes, I still continue to use a FSC now & again as good PM. I'm just careful in doing so as even with new sensors, too much FSC will trigger the CEL. But she'll still run fine!
