Hey everyone. First post on this forum here. I have a 1998 GMC Jimmy (4.3L V6) with almost 122k miles and I take good care of it, especially with the oil changes. I have used Royal Purple in the past before they switched to the new SN formula. But mostly I have used Mobil1 High Mileage over the past 2.5 years (after I started doing my own oil changes after seeing that I could change my oil with synthetic and a good filter for LESS than what local shops charge for conventional oil and a FRAM filter. Plus I don't screw it up or forget things. I have had grease left all over the driver's side, no grease for the front end and other more serious blunders) with a Napa Gold or Purolator PureONE filter along with a magenetic drain plug. I normally do oil changes around every 2500 miles. This engine runs fairly well. No contaminated oil and only some minor lifter tick when it is wet out or when it is cool. Since I do alot of stop and go/mountain/high speed highway/cold starts in various temperatures, I use high mileage full synthetic oil with an API rating of SL because of the ZDDP content (Mobil1 HM is currently the only oil in that category). Lately, since I am coming up to my next oil change and seeing the new oils on the shelf at Walmart, I have been reviewing the oil brand to use in my truck. I have been looking at the ads for Quaker State Defy and noticing it has alot of zinc and has an SL rating. However, I am concerned about the fact that it is a synthetic blend. Which oil is better in terms of wear protection/cold starts/zinc content, etc? Except for some lifter noise and slightly lower oil pressure (probably not due to the oil), I have not really had problems with Mobil1 High Mileage and I am looking for reasons to switch and reasons not to switch. Thanks
