sears SYWR $30 off $30 surprise
by eljefino
07/25/16 05:03 PM
Does BG 44K work?
by j_mac
07/25/16 04:56 PM
First CEL on the SRT-8
by OVERKILL
07/25/16 04:00 PM
How wide are the error bars on Seq IIIG tests?
by bulwnkl
07/25/16 03:15 PM
Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Luuey, Eskimio, Jngoose76, Ken_Clifton, HotDog15
58592 Registered Users
86 registered (AnthemBassMan, 69GTX, 1JZ_E46, 182RG, 2010Civic, 440Magnum, 8 invisible), 2017 Guests and 23 Spiders online.
58592 Members
66 Forums
252236 Topics
Page 2 of 3 < 1 2 3 >
#2838421 - 12/17/12 07:06 PM Re: Making pure gas from E10? [Re: Kestas]
tig1 Offline
Loc: Illinois
Why would you want to do this?
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2838588 - 12/17/12 09:26 PM Re: Making pure gas from E10? [Re: Kestas]
Kestas Offline
Loc: The Motor City
To prevent phase separation and the subsequent gelling and corrosion that follows in my equipment. I'm not always diligent in draining the OPE fuel quickly after the season. Plus, one never knows when the last use of a snowthrower may be in the season. One gallon is all I've prepared.
There may also be the added benefit of running pure gasoline, as my old equipment was designed to run. I have a 40 year old snowthrower, 30 year old lawnmower, 30 year old chain saw, 20 year old leaf blower, and 20 year old generator. I'm not about to replace all this equipment for the sake of E10.
I may even consider doing this for my 41 year old car. Though I suspect it'll be cheaper to retune it properly.
#2854165 - 12/31/12 08:51 PM Re: Making pure gas from E10? [Re: Kestas]
flstffxe Offline
Loc: MN, USA
Originally Posted By: Kestas
Pure gas isn't as easy to come by in Michigan as it is in Florida.
This site may help you.
pure-gas.org Michigan results 120 stations
#2854676 - 01/01/13 12:05 PM Re: Making pure gas from E10? [Re: Kestas]
Kestas Offline
Loc: The Motor City
I've been on that site many times. Most of the stations are at marinas. None are near me in Livonia. None are along any of my commutes. The closest station is listed across town in Allen Park and would cost me $10 in gas just to go there. Then there's the chance that if I go there, the listing could be a goof and there is no pure gas.
Go on that web site, pure-gas.org, and click on "map". Compare what you see at the Detroit area with the Minneapolis-St. Paul area and you'll apprieciate how difficult it is for me to find pure gas.
It's just so much easier and cheaper for me to wash premium fuel.
#2861311 - 01/07/13 10:08 AM Re: Making pure gas from E10? [Re: Darkfire]
THE_TROTS Offline
Loc: Wixom, MI
Quote:
After I do all of the above I add 1 ounce of seafoam. If you still weren't comfortable with that you could add a small amount of iso-heet red bottle.
I guarantee that if anyone tries this that whatever you run it in will run noticeably better than on E10.
Even before any isopropyl is added, there is zero water visible at the bottom of the remaining gas that was just filtered. I confirmed this by dispensing it in a clear container and inspecting it.
Why would you remove alcohol from fuel just to add more alcohol?
Some random old GM
1993 Lexus ES300
1982 Kawasaki KZ550 LTD
Toyota Parts Counterperson
#2861849 - 01/07/13 05:54 PM Re: Making pure gas from E10? [Re: tig1]
OilFool Offline
Loc: NNJ
Go to any Landscaping shop that repairs equipment and ask about Ethanol in fuel.
Apples to Oranges some may say...
But it does, at a minimum, cost MPG with E10 vs E0.
My handwritten numbers coincide within 0.02% of an App I use as well as the ScanGuages.
#2951875 - 03/26/13 08:24 AM Re: Making pure gas from E10? [Re: Kestas]
Silverado12 Offline
Loc: Central Virginia
A good alternative is to run Lucas fuel treatment in your gas. It mixes with your gas and gives everything a slightly oily coating. Works well for lubing elec fuel pumps in your car. Mix 3 oz per 10 gal gas. You could also run the gas out of your small engines before putting them away for the winter.
Edited by Silverado12 (03/26/13 08:24 AM)
Edit Reason: sp
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
15 Chevy Cruze 1LT auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
10 Mustang GT auto
#2955890 - 03/29/13 07:38 PM Re: Making pure gas from E10? [Re: Kestas]
HerrStig Offline
Loc: Boston, MA
Consumer Reports in the latest issue advocates buying eight buck a quart "pure gas" from Hagar's Dustbin and such places for OPE, and CU isn't often encouraging "free spending" on such things unless there is a reason.
#2957450 - 03/31/13 09:24 AM Re: Making pure gas from E10? [Re: Silverado12]
HerrStig Offline
Loc: Boston, MA
Lucas may do nothing more than coat the inside of a motorcycle fuel tank during storage, but that's enough reason for me to keep some around for the two wheel fleet.
#2962391 - 04/04/13 04:29 PM Re: Making pure gas from E10? [Re: Kestas]
Coprolite Offline
Loc: TX
I just use Stabil generously and call it a day. Believe it or not the PP/PU and clean air filters have the biggest impact on my lawnmower. The Stabil keeps the gas fresh even into the next year, so I don't really stress about that part of the equation. It includes a carb cleaner and would stabilize even E0 gas...
#2974242 - 04/16/13 08:21 AM Re: Making pure gas from E10? [Re: Kestas]
KenO Offline
Loc: Auburn, GA
OK, question on the fuel washing - what do you do with the byproduct (water + ethanol)?? Can it be used for anything?
1995 Volvo 960 ShagginWagon
1995 BMW 328ti
1997 Chevy C2500 5.7l V8
1998 BMW 528i
#2975636 - 04/17/13 12:56 PM Re: Making pure gas from E10? [Re: Kestas]
Coprolite Offline
Loc: TX
Hazmat waste container filler.
#3187780 - 11/14/13 03:51 PM Re: Making pure gas from E10? [Re: Kestas]
Shaman Offline
Loc: Frankfort, Kentucky
Washer fluid if there isn't any gas in it. The washer pump seals would swell fast enough if there was
#3189185 - 11/16/13 05:42 AM Re: Making pure gas from E10? [Re: Kestas]
Shannow Online   content
Loc: Oz
Shaman,
great thinking
methylated spirits is about $3-6 a litre here, the ethanol component of petrol 15c, or $1.50 neat
#3194746 - 11/22/13 11:41 AM Re: Making pure gas from E10? [Re: Shannow]
sdowney717 Offline
Loc: Newport News, VA
Washed gas works great in small engines.
What is washed out is alcohol and water, so then let it dry out in the air.
such as poured out on the driveway.
The government should make washing gasoline a punishable crime as it works so well and circumvents the EPA polluting the air rules.
If you see your neighbor doing these things, can't you call the EPA on them and get a reward for being a snitch?
I think the government encourages this behavior.
