For the cold in your area, you do not have to shell out a bunch of cash for a super grade of oil for cold starting. You can do like we did in Alaska... get an oil pan heater. It can be plugged in, on a timer if you choose to, and you will get oil to the top like a warm summer day on start up. In conjunction with a block heater, you have a winning combination for the coldest climates. Oil pan heaters are cheap and easy to install. They don't use a lot of electricity. There is not one piece of equipment I own or vehicle that I have owned for 3 decades that did not have one. My new semi, when I ordered it, came with not only a block heater, but per my spec's, an oil pan heater already installed.
