F1 - 2016 Russian Grand Prix
by gofast182
Today at 06:03 AM
VR1 Only suitable for 3 month / 3000mi oci's?
by FordCapriDriver
Today at 04:07 AM
4-year old oil in a sealed container
by rickeroo
Today at 12:05 AM
Cowboys fans should be happy tonight.
by deven
Yesterday at 11:03 PM
2012 Civic - MaxLife ATF update
by sw99
Yesterday at 10:58 PM
Champ PH820 on closeout at Rockauto
by sw99
Yesterday at 10:52 PM
Is two years too long?
by kohnen
Yesterday at 10:34 PM
Keep getting TR.APK popup on S III cell phone...
by daves66nova
Yesterday at 10:16 PM
Curse You Road Salt Version 2
by Oldtom
Yesterday at 07:34 PM
Anyone have advice for moving a cat cross-country?
by earlyre
Yesterday at 07:23 PM
MLB baseball games are very expensive
by Joe1
Yesterday at 07:20 PM
Additive technology used in Euro mid-saps oils
by skyactiv
Yesterday at 05:41 PM
carver1, Handy7rick, sicilien, Crater_77, hiker17
57737 Registered Users
51 registered (AirgunSavant, alarmguy, Al, 97f150, 2015_PSD, 2009Edge, 5 invisible), 1009 Guests and 294 Spiders online.
57737 Members
66 Forums
248197 Topics
Page 1 of 3 1 2 3 >
#2716268 - 08/16/12 10:24 AM what tire pressure to go by??
lucerne06 Offline
Loc: northeast
Should I go by the recommended tire pressure on my car label??? or do I go by the tire manufacturer recommendations??
And what if I put in 32 or 34 lbs instead of say 30 as called for on the car???
#2716272 - 08/16/12 10:29 AM Re: what tire pressure to go by?? [Re: lucerne06]
Quattro Pete Offline
Loc: Great Lakes
You go by the PSI on the car label, and can adjust a few PSI up from there.
The tire manufacturer only lists the MAX allowable PSI, but they have no idea what car you're going to mount their tires on.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2716279 - 08/16/12 10:36 AM Re: what tire pressure to go by?? [Re: lucerne06]
BrianWC Offline
Loc: Louisiana
2002 Honda CR-V EX AWD
2014 Ford Mustang GT
2015 GMC Yukon XL SLT
#2716281 - 08/16/12 10:36 AM Re: what tire pressure to go by?? [Re: lucerne06]
4x4chevydude Offline
Loc: Northern IL
Go by the car and you can always add a few psi if you would like to
2000 Chevrolet K2500 5.7 Old Body Style 6" Lift and 33" Tires 149k Miles
1998 Buick Century Limited 3.1 91k Miles
#2716287 - 08/16/12 10:41 AM Re: what tire pressure to go by?? [Re: lucerne06]
sasilverbullet Offline
Loc: San Antonio, Tx
Before I give my .02, what yr/make/model of car and exactly what kind of tires? There are a lot of variations to my answer, all depend on the above information.
14 Honda Civic 4dr EX-L - Mobil 1 Ext Perf 0W-20 & M1 Filter
14 Honda Accord 4dr EX-L 4cyl - Mobil 1 Ext Perf 0W-20 & M1 Filter
#2716304 - 08/16/12 10:53 AM Re: what tire pressure to go by?? [Re: lucerne06]
HerrStig Offline
Loc: Boston, MA
There is a direct relationship between "slip angle" which affects handling, tire wear, and ride quality. For a particular vehicle, there is usually a sweet spot, but that can vary depending on the actual tire on the car. The car companies have a tire pressure in mind which is a good compromise based on what they are supplying as OEM , but if you go up a rim size and width and fit a "performance" tire with a stiff sidewall and additional belts, it may be well off. The companies can't control what you replace OEM with. For example, overinflation usually affects a wider tire sooner than a narrow one. Radials don't telegraph underinflation to the driver as quickly.
In the racing world, tire pressure is set by using a "tire pryometer" which measures temps across the tread. The techs shoot for even heating. Hot spots point to inflation problems and/or alignment issues. We can't do that with a daily driver, so using an accurate gauge and getting a feel for adjustments is the best we can do. Don't just assume that more air is better.
Edited by HerrStig (08/16/12 10:54 AM)
#2716308 - 08/16/12 11:00 AM Re: what tire pressure to go by?? [Re: lucerne06]
ARCOgraphite Offline
Loc: N.H, U.S.A.
+1 on the sweet spot.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#2716325 - 08/16/12 11:14 AM Re: what tire pressure to go by?? [Re: lucerne06]
CapriRacer Online   content
Loc: Somewhere in the US
If you are using the same tire size as listed on the vehicle tire placard, then the pressure listed there is appropriate. If you are using a different size, then the pressure has to be recalculated. The calculation isn't difficult, but it involves the use of tire load tables which are not published on the internet. But I have a copy and am willing to it.
As others have indicated, what is written on the sidewall of the tire is NOT a recommendation.
And lastly, a few more psi is not a big thing. But be aware that ride quality suffers as pressure goes up.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#2716327 - 08/16/12 11:16 AM Re: what tire pressure to go by?? [Re: lucerne06]
Rand Offline
Loc: NE,Ohio
I usually start at oem +2psi to +4 psi and adjust from there.
in my case its 32/30 which felt way to soft.
35/33.5 is pretty good.. and if I'm towing long distance I bump the back up to about 36-37
I had tried 36psi all around but it felt abit harsh.
Edited by Rand (08/16/12 11:17 AM)
2015 Forester I-Premium 6MT
#2716361 - 08/16/12 11:38 AM Re: what tire pressure to go by?? [Re: CapriRacer]
Rand Offline
Loc: NE,Ohio
is this similar to your load tables capriracer?
http://toyotires.com/tires-101/load-and-inflation-tables
#2716390 - 08/16/12 12:04 PM Re: what tire pressure to go by?? [Re: lucerne06]
ag_ghost Offline
Loc: SF Bay Area, CA
No arguments with the repiles; but like most people, I don't check the pressure as often as I should; so I always go above the listing on the door jambs. Wear from underinflation is far more common than the opposite.
66 Mustang (289)-Valvoline VR1 10W30
63 Galaxie 500 (390)-Chevron 10W40
99 Accord V6-Chevron 5W30
15 CR-V M1 EP 0W20
#2716399 - 08/16/12 12:19 PM Re: what tire pressure to go by?? [Re: Rand]
buster Offline
Loc: NJ
That is what I've always done too.
#2716424 - 08/16/12 12:44 PM Re: what tire pressure to go by?? [Re: CapriRacer]
Donald Online   content
Loc: Upstate NY
Best to keep same tire size and the PSI on the manual and/or door sill. Straying from that will cause problems from a balanced perspective (ride, handling, tire life, load capacity).
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2716445 - 08/16/12 01:21 PM Re: what tire pressure to go by?? [Re: lucerne06]
Chris Meutsch Offline
Loc: Cincinnati
I go 3psi over the plate's recommendation. 29 is 32 on the CR-V, 32 is 35 on the Pilot.
"I bow to the master troll engineer20."
---cptbarkey, 3/21/16
#2716451 - 08/16/12 01:26 PM Re: what tire pressure to go by?? [Re: lucerne06]
wirelessF Offline
Loc: Oahu, Hawaii
For some reason the rear PSI for rear tires on a empty pickup truck is too high. For my trucks they call for 35 PSI rear but I'll lower them down to 26 PSI. Before carrying a heavy load I'll air them back to 35 PSI or higher.
Page 1 of 3 1 2 3 >
