I have used Bars Leaks 3 times, and it has worked 3 times. I think the condition of the radiator is important, and it probably won't fix a leaky clogged up radiator, a good flush first is essential.
It should work with Dexcool as it says on the bottle "works with all modern antifreeze mixtures, including OAT mixtures". I think it may work better if the system is drained, flushed and the Bars Leaks added to plain water. That said, I have just added some to my car, with green stuff still in the system.
