After I spend some time on the inherited, beat up, 93 Ford Escort and a owned since new 95 Corolla, I'm coming up to the follow conclusion of the design philosophy difference between domestic and import:
1) Domestic seems to put more advance control/design in the car vs the import. You see waste spark ignition instead of mechanical distributor rotor. You also see the MAF sensor in the air box away from the throttle to reduce contamination.
2) Import has better plastic quality and more traditional layout. The plastic doesn't seems to get as brittle and with less sharp edges in import as the Fisher Price like fit and finish of the domestic.
3) Import has less feature but more durable interior. The soft rubber part in domestic seems to not have rigid integrity that domestic has, and they seems to "melt" out of shape and lost a paint and reveal a black internal compare to the import.
4) Domestic seems to have more stable "handling" and taller gearing, even with bigger displacement the domestic doesn't feel as much "oomph" as a smaller import in city driving. At highway driving domestic seems to cruise with lower rpm and smoother drive.
I notice similar characteristic between an 08 Malibu rental vs an 07 Camry loaner.
