Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
QS filters 'closer' to OEM quality?
by addyguy
07/26/16 07:44 PM
Need tire experts regarding tire wear pattern.
by ST2008
07/26/16 07:18 PM
Best not drying grease
by ST2008
07/26/16 06:56 PM
Honda GCC160 crank question
by FastLane
07/26/16 06:55 PM
by Pokermatters
07/26/16 06:52 PM
Sunl Scooter Troubleshooting
by yeehaw1960
07/26/16 06:47 PM
Ozonated Distilled Water in the Cooling System
by ZeeOSix
07/26/16 06:42 PM
2001 Honda Accord 4 cyl
by gmh101357
07/26/16 06:25 PM
No Oil Additives with MDS System - Ram 2500 6.4L
by Dexters
07/26/16 05:39 PM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
116 registered (41 Plymouth, Anduril, acbent, 4WD, ag_ghost, 13 invisible), 1895 Guests and 23 Spiders online.
58600 Members
66 Forums
252287 Topics
Page 1 of 2 1 2 >
#2689395 - 07/20/12 12:00 AM Re- using oil from a race car
Hendo Offline
Loc: Australia
Hi All
Here's the question. At Uni, we build a car for a competition called FSAE. Pretty much design and build a car from scratch to race against other Unis. We run a R6 motorbike engine and use moto specific oils and have tried 5w30 (motul 300v), 10w40 and 20w60 oils to do get data for the car (we're having surge problems)
Each fill (4l, custom dry sump) is in there for less than 5 hours. I have filtered and kept the used oil, and I'm after people's opinion on using the oil again in road cars (mostly beaters)
How badly does racing affect the oil? I'd guess it has sheared a little and discolored due to high temp, it just seems a shame to waste double ester oil after 5 hours use! what's the consensus?
#2689396 - 07/20/12 12:04 AM Re: Re- using oil from a race car [Re: Hendo]
tommygunn Offline
Loc: usa
Depends on the kinda racing really.
I dunno. For beaters? Fine. But its impossible to know what kinda fuel dilution the oil may have suffered.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2689397 - 07/20/12 12:05 AM Re: Re- using oil from a race car [Re: Hendo]
dave1251 Offline
Loc: Maricopa, AZ
Without a analyst my biggest concern would be fuel dilution. But if we are talking oil for a beater I would not worry about it too much especially if you are not attempting extended OCI's. I am telling what I would do in this situation. But I do a lot of things I do not recommend others to attempt.
don't use.
#2689404 - 07/20/12 12:18 AM Re: Re- using oil from a race car [Re: Hendo]
Hendo Offline
Loc: Australia
As far as fuel dilution goes, we run the engine leaner than factory (minimum 13:1 a/f ratio) because part of the competition scoring is fuel efficiency. I'm guessing this means fuel dilution is less of a problem...
The racing we do is autocross, laps around a kart track with heaps of cones. Each run is short, <20mins
Edited by Hendo (07/20/12 12:20 AM)
#2689406 - 07/20/12 12:20 AM Re: Re- using oil from a race car [Re: Hendo]
jjcom Offline
Loc: Illinois
If you're not running them real rich, or running them extremely hot for a long time, more than likely I'd say the oil still is "ok". I wouldn't throw it in a good car, but if it's one thats drinking oil like it's water, then I'd say you're fine.
2014 Chrysler 200 2.4
2007 Grand Prix 3.8 Pennzoil Platinum 5w30
1930 Ford Model A Stock Rotella 15W40
#2689407 - 07/20/12 12:21 AM Re: Re- using oil from a race car [Re: Hendo]
Kuato Offline
Loc: In transit...
Why not have a UOA done on the used oil? Then you will know for sure.
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#2689546 - 07/20/12 08:58 AM Re: Re- using oil from a race car [Re: Hendo]
gfh77665 Offline
Loc: Southeast Texas
5 hours on the oil? Are you kidding? I would run that in a NEW car in a heartbeat! I don't think there would be any fuel dilution, but even if there was it would quickly burn off in normal highway driving. Thats good oil, just 5 hours old!
#2689838 - 07/20/12 02:06 PM Re: Re- using oil from a race car [Re: Hendo]
mechtech2 Offline
Loc: Chicago Area
For a beater? Use that oil!
Thank you for recycling, too!
#2689946 - 07/20/12 03:49 PM Re: Re- using oil from a race car [Re: Hendo]
TFB1 Offline
Loc: VA
In a passenger car engine that has no real issues, any residual fuel should be evaporated in a couple hours of normal operation...
#2691422 - 07/22/12 02:19 AM Re: Re- using oil from a race car [Re: Hendo]
Hendo Offline
Loc: Australia
Fantastic. Thanks for the advice, I will probably blend it with a HDEO for the beaters- ester + calcium cleaning goodness!
#2691425 - 07/22/12 02:29 AM Re: Re- using oil from a race car [Re: Hendo]
Shannow Online   content
Loc: Oz
I don't think FSAE would beat the oil up too bad.
Which Uni ?
#2691618 - 07/22/12 11:08 AM Re: Re- using oil from a race car [Re: Hendo]
GMorg Offline
Loc: Mizzou-land
So, you have decided that the oil should not go back into the race engine and it may be OK for your beater. Where do you draw the line?
Also, how do you filter the oil? How large of a particle will make it through your filter?
#2691768 - 07/22/12 02:04 PM Re: Re- using oil from a race car [Re: Hendo]
HTSS_TR Online   content
Loc: Lake Forest, CA
I filtered the used ATF from E430 to use in the LS400 leaking power steering this way:
Stub 5-6 paper towels tightly into the long ATF funnel, place the funnel into 5-qt jug then pour ATF into the funnel. The ATF is filtered at the rate of less than 1/4 pint per hour. For 4 quarts it took more than a day.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2691777 - 07/22/12 02:16 PM Re: Re- using oil from a race car [Re: HTSS_TR]
Highline9 Offline
Loc: ca.
wow a real redneck filter, I would do the same.
2010 challenger R\T
2014 mercedes glk350
2003 hyundai elantra
1992 dodge w250 cummins
#2691793 - 07/22/12 02:48 PM Re: Re- using oil from a race car [Re: Highline9]
Low cost (5-6 paper towels) with good filter, what not to like ? grin2
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
Page 1 of 2 1 2 >
