Originally Posted By: mechtech2
Wrong. Neither they nor others have solved anything. They have addressed the issue, and some have attenuated it to a degree.
Good oil does seem to help a bit. Extra upstream injectors can help, but then why bother with the DI system?
The car will run pretty good for a LONG time, but build up is inevitable, and some performance/breathing is diminished.
No solution is here yet with DI engines.
I'll buy this explanation, based on what I've read everywhere else so far. Now, define "a LONG time". Is it a 100K miles, 150K miles, or a lot less? My '03 P5 has 75K miles on it. It still beats the EPA mileage estimates, uses no oil between 10K mile oil changes, and has had Mobil1 in the engine since new. Can I reasonably expect that of the DI Skyactiv motor also?
