Not sure why this never really clicked in my mind, probably because of all the weird theories and superstitions I've heard over the years about torque and horsepower, but the recent thread about flat torque curves did it.
I've heard so many people say so many different things: "OK, when you're starting from a dead stop, that's when you need torque." Or, "For towing, you really need an engine with lots of torque." IOW, for some things you need horsepower, for other things you need torque. Well, please pardon me if I say, "Horsefeathers."
When we talk about engines, torque IS horsepower, because of the formula torque x rpm /5252 = hp. Engine torque is calculated at a particular rpm which means it's not static torque.
I believe the current 6.7L Dodge/Cummins diesel makes 350 horsepower at 3013 rpm. It makes 800 ft. lbs. of torque at 1600 rpm. That's a lot of low end torque, but it's also 243 horsepower. 243 horsepower at 1600 is also a LOT of low end horsepower.
I remember years ago seeing a rating plate on a Cummins diesel in an over-the-road tractor. It said the engine made 350 hp at 2000 rpm and 1400 ft. lbs. at 1200 rpm. That's about 320 hp at 1200 rpm.
So whether you say you want low-end torque, or low-end horsepower, or low-end grunt or whatever, it's all the same thing.
