Originally Posted By: xBa380
My 2008 xB I took in for an ignition coil recall a few weeks ago. They did the recall and the very next time I started my car the next morning my airbag light was on. Shut the car off and turned it back on, light went away.
Left school later that day and the light was back on. Called the dealer right away telling them the light has been on since getting the work done the day before. I took it in and they did their "diagnostic". An hour later, they told me there was a "hole" in the passenger side airbag harness, and the repair was $1200. They said Toyota agreed to cover half the cost. I told them I have to think about it and left (after paying $50 for them to look at the issue... although I never had it until they did work the day before...)
Airbag has not been back on since... It has been three weeks now. They did reset the battery, which they never unplugged when they did the ignition coils. So they cleared the code and reset the battery and all has been well. No problems since.
Maybe try doing that? If you still get the light, got to autozone and get the code. Look it up online and find what it tells you.
Hopefully you get it fixed!
Maybe I should unplug the battery if the light comes back. I heard that not all diagnostic readers can interpret codes from the SRS system, since it is somewhat 'apart' from the OBD II system. Also, I believe that the SRS system triggers a light only when a problem is recognized, and goes away immediately upon that problem going away (unlike a CEL, which stays on until the problem has gone away for a certain period of time). I have also read of other Focus owners mentioning that an SRS light can be triggered by low voltage coming from the battery. My car always starts fine, but it does have the OEM battery, which is over 5 years old.
