I've been inspired to make a plot showing my decrease in fuel economy:
(The blue line is exponentially smoothed to show trends.) The fuel economy seemed to drop off around 122,000 miles. The last two points are since I replaces the PCV valve. I think keeping careful fuel records pays off when finding small trends like this, especially since my car is due for a smogging in a couple of months. (Aside from the big spikes that represent long trips, my driving patterns are consistent, which also helps.)
Patman, on my Civic engine, the PCV valve is under the fuel rail to the right, as you're standing in front of the car. It's connected by a hose to the intake manifold. If you clamp the hose strongly with the engine idling, you should hear a click as the valve goes from closed to open. In my case, the valve seemed to be stuck open, because the idle changes when I clamped the hose. (Normally the valve is open at low manifold vacuum and closed at high vacuum, e.g. idle.)
To replace the valve, you just pull it straight up, out of its rubber grommet and detach the hose. Installation, as the manuals say, is the reverse of removal. I've read on honda-tech.com that some aftermarket valves don't seat deep enough into the grommet and can leak oil, which is why I went to the dealer.
The ubiquitous Mista Bone has a picture of where the PCV valve is relative to the intake runners (in a D-series engine):
http://home.cinci.rr.com/mistab0ne/Pics2/PCV.JPG
[ January 03, 2003, 02:03 PM: Message edited by: BOBISTHEOILGUY ]
