Old article, but brings up an interesting point...
NJ
http://www.imakenews.com/lng/e_article000351473.cfm?x=b16kqbNJ,b16kqbNJ,w
Quote:
All, except for Mobil 1 Extended Performance, are API licensed for the most current categories, ILSAC GF-4 and API SM. Mobil 1 Extended Performance is not currently licensed because it does not meet the fuel economy requirements of GF-4 as measured by the Sequence VIB engine test. It does, however, meet the engine durability and protection requirements of the specification. The company said it is doing a considerable amount of work to meet the fuel economy requirements while retaining the 15,000-mile guarantee. “Technically its doable,” said Olszewski, “We’re well under way and expect to get there.”
They later approved it for GF-4. Mobil 1 EP is currently GF-5/SN, so it also meets the fuel economy requirements.
I'm not sure some of the smaller blenders that claim they are predominantly Group IV based and use little/no VM'ers meet the VIB test. That could be one reason why they are not licensed. It's a trade off. Oils like Redline and some of Amsoil's would probably not meet it, but on the upside you get a more shear stable oil.
Is Edge still a 15k mile oil?
t's what happens when moron bureaucrats are allowed to make technical policy. I could give a bleep about half a mile per gallon in a 30 mpg car, but I want the thing to LAST. Keeping cars longer has to have a positive environmental consequence equal to or better than the slight MPG improvements the bureaucrats tr to ram down our throats. It really IS time to take this country back.
I don't believe Edge makes the 15,000 mile claim anymore. I'm sure you are aware that many of us here had strong doubts about that initial claim.
The wear requirements for GF-5 are exactly the same as for GF-4. DEXOS is higher. You may not care about another half mpg, but on a national scale it means that we send less money to foreign oil produces (no, we who possess 2% of the world's oil reserves and consume 20% of the world's oil cannot solve the problem by drilling more). The actual specs for the oil standards are set by a committee composed of engine makers, oil makers, and chemical additive makers. Not bureaucrats.
http://www.gf-5.com/gsuniverse/sitetemplates/gf5/images/spider diagram color.png
That is probably the best graph I have ever seen that compares the differences on those oil requirements. Thanks!
Huh, I'm inspired to try dexos1 approved oils and try to compare oils hopelessly via UOA vs GF-5/SN spec'd oils without the dexos1 grade...but hey, maybe those 'only' approved for GF-5/SN 'meet or exceed' dexos1 labeled oils already?
@#mindblown
This is false. This statement is scary wrong!
To not get political, I won't give links.
But Google things like myth of 2% oil, we have 60 times oil, Mr 'X' misleads on oil reserves.
This was front page news n economic papers in the middle of march.
