Anyone have a block heater and also an oil temp gauge? How effective is the conductive heat from the block/water at heating the oil? Since Jan I've had less than a 3mi commute which has got to be destroying my engine. Looking forward to next winter I know an oil pan heater will be best, but I'd like the benefits of improved fuel economy and immediate hot air that a block heater would bring. The car also has a oil/water heat exchanger from the factory so having high water temp from the start will warm the oil up faster.
My engine calls for 5W-30 and 5W-40, but 5W-20 or 0W-20 will go in for the winter season.
