I actually DO have experience with Evans NPG+. When I did my installations, they did not sell a prep product to dehydrate the system prior to use. I have it in two machines, one a small farm tractor that we work really hard and which has a small cooling system; the other is a GL1800 Honda Goldwing which also has a challenged cooling system. Is it worth it in an automobile? Very doubtful. It will work great, it is permanent, it does not corrode, it does not freeze, and within any practical sense it will no boil over. But most folks simply don't keep their cars long enough to experience cooling system failures. If you change coolant on schedule, you can wear the car out on regular e-glycol and water mix with no problems. ALso, getting the vehicle prepped for Evans is a royal PIA. Drain, flush with addititve to remove any corrosion or scale. Fluch that away, and then dehydrate the system with full strength propolene glycol coolant (such as Sierra) or their prep product once or TWICE $$$. You want the system to be very dry, like a good martini.
But for me, the tractor is still working like new since 1982. The Goldwing has over 100,000 miles (over 80,000 on Evans) and on a very busy stop and go warm day it went to the top of Mt Washington while many cars and cycles were on the roadside puking coolant. Several other such rides. If you worry about radiator hoses or clamps, the Evans can be run without a pressure cap and thus little challenge to leak prone joints or wear and tear on hoses. It is best applied to special situations.
prs
