Originally Posted By: sleddriver
Good info, but I disagree the 5 cylinder turbo motor is known for sludging up. Any motor will if dino oil is run long enough without a change & filter, particularly in a hot climate like LA
I can only agree with you regarding the sludge and the 5-Cyl whiteblocks, To get sludge in those is very difficult if they are maintained as they should with a full synth oil.
Since i live in the Volvo country Nr.1 i have looked at more Volvo oilcaps than i can remember and if they are dealer serviced sludge and buildup is very uncommon.
The only cars with sludge i have seen is when some bozo have used a dino 10-30 or 10-40 in the whiteblock Turbo which is a big NO NO!
If a Dino oil have been used in those Turbo engines the PCV system will be clogged up very fast and sludge is very soon a fact.
I just went to my garage and took a pic of my oilcap and service history, The car have today
88856 Miles. and is a S60 2,5 Turbo 2005
1st service interval 31 745 kilometer =
19725 miles
2st Service interval 29 609 kilometer =
18398 miles
3st Service interval 28 428 kilometer =
17664 miles
Only
Castrol Edge 0W30 A5/B5 have been used since the car was new
and its the only approved oil for the 2005- whiteblocks here in Sweden.
My last oilchange i did myself with Redline.
I had a very limited amount of paper to wipe off the oil
from the oilfiller hole so the yellow on the pic is only oil and not varnish.
If your whiteblock is already sludged up the first step is to check the PCV system and its quite easy to do, Let the engine be on idle and then remove the dipstick and put a balloon on the dipstick hole.
The pressure should be negative so if you get the baloon filled with air then the PCV system is clogged up and need to be cleaned, There is not to just replace a PCV Valve on those engines its a quite big teardown process with removing the intake manifold and everything else and this is the second reason to never run anything else than a full synth in those engines, There is also a PYC nipple that is very good to clean at the same time near the turbo.
