Originally Posted By: Smokescreen
I own the same make. model and year. I was in communication with another owner in Australia who had this problem, he switched to 5w30 and the consumption slowed drastically. This is what is in his owners manual keep in mind this is the same car, whereas the North American CAFE version lists only 1....5/0w20.
In my owners manual it says "Toyota genuine oil or equivalent
Oil grade - 20w-50 and 15w 40
API grade SL or SM multigrade
10w-30, 5w-30, 5w-20 and 0w-20
API grade SL "energy conserving"
SM "energy conserving"
ILSAC multigrade engine oil
FWIW, I have zero oil consumption since 15 kms and I took ownership. My ECU has never been flashed. The oil level is still at exactly the full line at time of oil change, only there is just a slight darkening in oil color in the entire 10K km (6250mile) OCI. I was asked by a passenger if my car was a hybrid, because they couldn't hear the engine running.
I know the "warranty approved" answer would be to use the CAFE approved oil 0/5w20 indicated in the manual. However...I know an owner that has personally tested PP 5w30 and yielded zero oil consumption, zero increased fuel consumption compared and a quieter running engine.
Makes sense that the increased oil pressure from thicker oil would help, I think the real culprit is the OCV and its screen getting clogged.
