Originally Posted By: Kestas
AAA reports that (barring accidents) only 3% of car owners keep a car from cradle to grave. These 3% buy a car new, than run it into the ground until it is junked. We've done this to two cars in our family.
So typically, a new car buyer will divest himself from his vehicle long before it's used up.
We've done this with two cars.
The advantage is that with decent maintenance, the car remains fully functional for its entire life, and costs per year and mile end up being pretty low.
You'll likely replace maybe the starter and clutch (if it's a stick) along the way, and you may have to spring for a rad, a water pump and an alternator, but these are not usually expensive fixes.
With reasonable use, assuming you aren't grossly overwieght, the seats hold up fine, as does the rest of the interior.
