I was in walmart an hour ago and I saw that there was a new STP fuel system cleaner made especially for ethanol blend fuels. Here's STP's product description:
Removes ethanol fuel deposits and helps to restore lost power.
Although Ethanol is an environmentally friendly biofuel, it contains 33% less energy per gallon than regular gasoline which reduces fuel economy. Like regular gas, ethanol fuels can leave deposits on intake values and fuel injectors that further reduce fuel economy. Rust and corrosion may also form and damage fuel system components. This STP® product helps prevent rust and corrosion and removes deposits that can reduce engine performance.
Helps
Prevent rust and corrosion
Saves gas and lowers emissions by removing fuel system deposits
Restore lost power and acceleration
Usage Frequency
Use every oil change or 4,000 miles
Take Note!
STP® Fuel System Cleaner for Ethanol is safe for all gasoline engines.
I put a bottle of it in my del sol and Id love to see if it delivers. Even though at walmart on the shelf it was listed at $2.97 it rang up to $4.77. [censored] you walmart!!!
Helps
Usage Frequency
Take Note!
