Originally Posted By: AstroTurf
Originally Posted By: 38sho
yeah I've never torqued a wheel in my life!
I've never messed anything up using an impact gun. I take tires off left and right on all kinds of cars. I take my wheels off on my own car a lot and never have rotor problems or stud/nut problems. I'm using original rotors that probably have 100k on them, lots of heavy stops, drag strip passes, 100+mph hard stops, track day....... never the slightest bit of pulsation on my brakes.....
Then you Sir are amoung the many who do not understand that Brake Tolerances have changed. Before 7 thousands was accepted play, Now it is under 2 thousands and in some cases under 1 thousand. Also, do you not follow any torque specs? Why should this one be any different?
Thanks, Jim
Tolerance where?
Thanks, Jim
Tolerance where?
