I just finished servicing my wife's 2002 Nissan Maxima with 113,xxx miles. I honestly don't believe it has been done before, so I got a new WIX "screen" filter and gasket and 10 quarts of Amsoil ATF which meets the Nissan Matic-D spec that her care requires. This also was changed with the radiator which also acts as the oil cooler. A oil line runs throught he bottom of the radiator.
The manual calls for 9 qts in the transmission system. I drained the pan and measured, about 4-4.5 quarts. I add 4 quarts of Walmart SuperTech DexronIII/Mercon ($9.97), which also meets the Nissan Matic-D spec. I get my brother to help and we disconnect the oil line right before it goes back into the transmission. I crank the car and let idle and 20-30 seconds, at this point my brother can see the color difference in transmission fluid, so I shut-down the engine. I gave him this job, I'm color-blind and couldn't see the difference. He's also the electrician when we wire stuff. But anyways, theres another 4-5 quarts that just came out of the line, so then we drop the pan and change the screen. It wasn't a paper filter like most, but a screen and my brother and I agreed that we like the screen better. We get the new screen on and new gasket and fill with 4 quarts of Amsoil ATF. This stuff has a unique ordor and working a few hours around it spoiled our apetite for dinner. So with around 4 quarts of Walmart SuperTech in the "lines" and around 4 quarts of Amsoil in the pan, I crank and drain the Walmart SuperTech until my brother saw or smelled the Amsoil, then shut-down and add Amsoil to pan and measure on dipstick. Again, the manual calls for 9 quarts of ATF, I ordered 10 just in case. May not be your typical "flush" but I feel confident that there is little to no OEM ATF and 98-99% Amsoil ATF. Should be good for another 75-100,000 miles I hope. We do not have severe driving conditions. I haven't driven it yet to see if I can tell a difference in shifting due to some other repairs. Yeah, I've sunk about $400 in this car in the last week. Hoping it pays off...
