Originally Posted By: sentra
mechanicx, i have a strap wrench with a rubber strap, but i didn't think it will work, because the torque is a little too much.
Between, the bolt should be tightened to 123- 132 lb-ft, not the 140lb-ft i earlier stated. I mis-stated it. I will remove one of the belts and try the strap wrench. Also, sorry about my ignorance, but around where will i find this flexplate. I am a leaner in the field of automotive repair.
Scurvy, thanks for the advice. Using the impact wrench didn't seem like a good idea to me, either. No way to control how much torque is being applied.
Strap wrench will not work. That is just asking for trouble with that much torque.
The flexplate will be behind a cover, usually plastic. This will be located right where the engine meets the transmission around the bottom of it. Did you use a pulley installer to seat the puller first and now just trying to tighten the bolt? I always use the puller installer to put the pulley on because if you try doing it with the bolt you can strip the bolt or worse the crank and be in big trouble. You can rent a pulley installer form advance for free.
This is one thing you don't want to mess up. If you mess the crank up you will be pulling the engine.
