And if you "detected" what might be "perceived to be" a little understeer, what would be the harm in that? The car would go around the corner alright.
I guess my point would be to replace all 4 tires if you were concerned about handling. How can you compare 2 new tires with 2 old tires of different styles? The OP could just test drive it and then rotate fronts/rears and test drive again. He may correct his "perceived" understeer and place himself in jeopardy for traction loss on rears in emergency situations.
