I just did a cooler line flush on this transmission, I've been doing it about every 45,000 to 50,000 miles, the car has 232,000 miles on it now. As usual there was very little clutch goop on in the bottom of the pan and a minimum of very fine gray ferrous material on the magnets. I don't drop the pan every time but I hadn't done that for the past two changes and I wanted to see what it looked like inside.
I must say, that fluid is still working well in this transmission. I had thought about changing over to Dex VI (the manual specs Dex III) but in the end with a $35 off coupon from Advance Auto, I went with the M1 again.
I know I should have taken pictures but to tell you the truth there wasn't much to see. I've seen magnets on other people's cars that looked like sea urchins or porcupines, this was nothing. After over 230,000 miles I couldn't be happier with the way M1 has worked in this Aisin A540E.
