The only over the counter ATF I've seen that states "Meets Matic S" specs is Valvoline MaxLife.
Can I, or should I, use a syn ATF that "Meets Matic J" specs?
Is Matic S really that much better than Matic J? I know Matic S is spec’d for all the trannys that came with Matic J. Mine came with Matic S as OEM. Have the oil companies just not caught up with labeling the bottles Matic S?
Castrol Import Multi-Vehicle states Matic J but no S. I wanted to use the Castrol since it has worked better in our Honda than the MaxLife, but all the Matic "this and that" is confusing me!
