Milkman i charge $500 with new UIM,GM aluminum frame gaskets,new OEM GM coolant elbows,OEM thermostat,flush and fill with Peak Green or JD Coolguard original formula (customer choice) add $100 if the customer wants the injectors cleaned off the engine in the ASNU machine.
GM does not recommend leak tabs in the 3800,they are mostly used in the North* engines and even then only by placing them in the lower radiator hose not the radiator itself.
Any minor radiator or heater core clogging in the 3800 can become fully clogged up with the tabs and almost imposible to clear.
These 3800 non supercharged and ford 4.6/5.4 injectors get pretty dirty by 70k,typical Bosch design.The Delphi SC injectors flow so much they very rarely clog and mostly only need an in tank cleaner if anything.
