I have an 02 Olds Intrigue with the 3.5 v6. Today the check engine light came on. On the way back home, I stopped at Auto Zone and they pulled code P0131 and P0137. These are codes for the front and rear O2 sensors. Symptoms for these codes include: defective sensor, vacuum leak, engine running lean, or low fuel pressure. The lady at the desk tried to sell me both sensors. My thing is, both of these codes popped up at the same time. What are the odds of both sensors being bad at the exact same time? Rather, I would rather believe they are both telling me the car is running lean. I do not see any vacuum leaks, the engine does not idle fast, and the car runs fine. Any suggestions? I'd hate to replace both sensors to find out that it is still telling me the car is running lean. The fuel filter has been changed within 30k miles. The car has about 95,000 miles on it. I changed thePCV valve maybe 6 months ago. I am waiting till 100,000 miles to change the plugs. I doubt it would be bad plugs because if they were bad it would cause it to run rich not lean right? Help me out. Thanks.
Ryan
Ryan
