Our 2016 edge with 91k and the 2.0L ecoboost started running rough last couple of weeks at start up for about 30 seconds and on Thursday my wife called saying it was running really rough starting up and finally threw a code. I was expecting to replace the evap purge valve based on symptoms but the code I pulled was P0304, cylinder 4 miss fire. Ordered new Motorcraft plugs and denso coils and got them all swapped out today. Very easy to swap out. Took me an hour taking my time and torquing to spec.
Fired right up and is now running good (for a while now hopefully).
I was already planning to buy new plugs for this and the fusion, I researched the cost 3 weeks ago and was planning on swapping them out this summer but the code beat me to it. OEM normal service interval is 100k.
When I pulled the #4 plug, it wasn’t as bad as I was expecting but the gap was significantly open. 1 and 2 had a lot of carbon build up. I usually run a gumout regane or Techron before an oci at 5-10K ocis, depending on the oil.
All of them pulled 1,2,3,4 in order.
Number 1
All the carbon falling off.
Number 4
Number 1
Number 4
