Thought I'd post some pictures from my weekend project -- checking the valve clearance on my 2007 Civic with 60k miles. It's a 1.8l with a manual transmission.
Busy SOHC 16 valve cylinder head with timing chain. Very clean. No varnish or discoloration I could see. 60k miles on 6000-6500 mile OCIs with good dino oils (and sometimes motorcraft syn blend), all 5w-20.
Close-up. You can just barely see the camshaft under the rocker arms. The lobes are small and numerous since it drives 4 valves per cylinder plus an extra lobe for the "economy" VTEC mode (hence 5 rocker arms per cylinder)
Wider shot of the engine bay with the cowl cover and valve cover removed just for reference:
Spark plugs. Recommended replacement is around 100k miles (they're iridium plugs). I guess they look OK but I didn't check the gaps (except to notice that they look even with each other).
Incidentally, none of the valves actually needed adjustment. The inspection isn't actually recommended until about 100k miles but I thought 60k was long enough. Apparently I was wrong.
