Guys:
I posted earlier that I had premature tire wear and poor handling due to over inflated tires. Note: I had inflated the tires to 34-35 PSI to improve gas mileage. I dropped them back to 31 PSI (manual says 32, but decided on 31 due to hot temperatures) and found the handling to be much improved. Gas mileage did drop about 1 MPG.
My advice: don't over inflate tires because it can cause accidents (lost the rear end while turning on two occasions) and produce premature tire wear (center tread). Seems to be critical on rear drive cars.
Another topic: got improved performance on Chevron gas vs Shell, both premium. Note: gas mileage a little worse, maybe due to cleaner injectors that provice richer fuel mixture?
Thoughts?
JR
1999 Lexus SC300, 144,000, Mobil EP
Thoughts?
JR
