Originally Posted By: 05ChevyI5
Would the flow rate differ greatly between these two filters?
If they do, it's probably small. Most oil filters if compared at the same flow volume only differ by a couple of PSI pressure drop across the media with hot oil. With cold oil, it might be up to 5 PSI difference.
