Originally Posted By: Benzadmiral
Update, all,
He did the pressure test this morning, and it held pressure perfectly. It turns out he has done these gasket replacements before, has seen what we're talking about. His advice to me was to put some of the GM sealing tabs in the coolant -- he gave me a packet of 'em; how many should I put in? -- and keep a careful eye on the level in the tank. He tells me the tabs should reduce the acidity in the Dex-Cool somewhat, "like Alka-Seltzer." And I'll have another UOA done after this oil change.
Bullet, it appears, dodged, for now.
Since the dealer has already sold me the car and they won't be risking blowing a sale, I could ask them to see if the work was already done at some point. If they did it, warranty or not, they should have the record of it. Or I could ask the previous owner, whom I see now and then at the barber, if he had any internal engine work done. Not likely, I guess, that the car would have needed the gaskets done at less than 44K miles, which is when I bought it . . . but if the work's been done, that would be a big load off my mind, hey?
Benzadmiral,
That's good news! If the coolant sealing tabs are the GM part number like I bought, info is to use the entire package of 6 added to the radiator when cold. That should be 40 grams and is appropriate for our car's size of cooling systems.
The GM type are kind of brown grainy "dog vitamin" looking things. If you have something other than this, or even if not, suggest you get your mechanic's advise.
You can expect the tabs to make your coolant look a bit murky and this will slowly cycle 'til it's visible in your coolant recovery reservoir, too. This is normal.
Regarding UOA: Please remember that these cars "hold back" about 1/2 quart of oil after draining in the bottom of the oil pan. And any previous contamination will stay right at the bottom of the pan. So if you continue getting pesking minerals "suggesting" coolant, you may want to use an oil extractor or whatever to vacuum out the last quart in the bottom of the pan.
It's your call of course. Just a suggestion if you keep getting mineral readings a bit off and want to rule this out.
Once you get things where you want them, I suggest putting a line on your coolant recovery reservoir wherever the exact cold coolant line is. This way, if it ever starts to drop, you know it right away.
Again, when my car was getting ready to suicide, it was dropping about 1/2" in about 1 hour of operation for whatever that baseline is worth. My Dad's car was about the same right before the hydraulique.
Your mechanic is the guy "hanging his hat" regarding the issue, so please DO allow his advice to take precedence over my own. Above are suggestions only and YMMV - especially on this UIM/LIM issue.
Congrats again on the good news!
Kind regards,
Larry S.
10*B
ASE Cert MM - Retired
