So I changed my transmission fluid a few days ago @ 139500 miles. I have taken some photos I would like to share with everyone. I went from ??? ATF that had been in it since I bought the car some 8k ago to now Valvoline Max-Life.
This is the color of the oil before and after .....
And this is the under side of trans and the pan. There were two magnets attached, one on the pan and a second one was stuck to the filter. I couldn't find the other two. I looked in several shops to see if any of them carried these magnets and had no luck finding two. I'll buy them when I find them and change them out on my next OCI.
Image Link
...so comments about the work: It was easier than I had ever imagined ...it would have been even easier if I were to buy the correct filter kit initially ...it took me until I dropped the pan to realize the gasket didn't match and had to ride my roommate's bike to pickup the correct kit (ProKing FK-285, I believe?). I followed advice from fellow BITOG'rs in another forum ~here~
I did the "power flush" by disconnecting the cooler return line after I drained the old oil replaced the filter, refilled with 4 Qts ....idle'd the engine and shifted through all the gears ...then checked to make sure it was level (while Idle) ...then stopped engine ....disconnected the cooler return line ....I thought it would be fine not to go without the additional 3/8" hose I bought from Advance on the cooler side and boy was that a mistake!!! I started the car and oil splewed a huge puddle over all the newspapers I layed down ...I was quick to fit the hose, though, and it ended up working perfectly because the hose was just right to go an inch from the top of 1 gal milk jugs I was using to store the used oil. It took me 12~13 Qts until I noticed clean red oil to come out the return. From then I made sure the level was correct when idle. However, because my dipstick doesn't shoot straight into the trans and snakes around components I am still not very sure if I am getting an accurate reading because the oil is still working its way down from the fillup to the pan. I may either be a quart too much or a quart too little I am not sure. ..
I have so far driven 300 miles since the change. I am about to move and recently my "check engine" light came on. I went to Advance and it gives me a catalyst error. Since then I have made sure all my fluids are good and they are. And I also put in a few gallons of 93 octane to see if that may help as well. Not sure if there's a link between my recent ATF change and this catalytic converter error I just got? What do you guys think?
Image Link
