I've sorted out my Camry's cooling system problem, turned out to be the sensor located on the bottom of the radiator - many thanks to everyone who has helped me out!
The second issue I'm trying to tackle is timing belt replacement. This is a 5S-FE engine with 61,500 km (38,440 miles) on it since 2001. The car is 9 years old (11/2000 build date) and still on the factory timing belt. It had 50,000 km (31,250 miles) put on it in over 8 years, and I just put 11,500 km (7,188 miles) on it over the course of the past year.
The replacement interval is listed as 150,000 km (93,750 miles) and no time scale is given. My take is a timing belt replacement (with the water pump, crank/cam seals and tensioner) is much cheaper than a cylinder head overhaul, so I'm willing to get this out the way within the next 2-3 weeks, preferably before the end of the year. Am I being overly paranoid? Or should I wait until the car hits 150,000 km?
Thanks!
