I have a new 1300 Tourer, its parked for the winter right now here in Alaska, it has right now just 43 miles on it, I was thinking of draining the factory oil right now and start it off with some regular Rotella T 15-40 not synthetic, after maybe another 500 or so miles next spring then maybe go to synthetic or should I wait until it breaks in further?
I am a heavy equipment mechanic but fairly new to working on motorcycles and recently this year I own two the other being a 1980 Honda CX 500 that just loves the Rotella T. I can see a lot of truth in the Motoman break-in procedure and when the roads clear up I will continue doing just that, the materials in this engine are cutting edge stuff thats superior to what I have seen in other engines. Also whats a superior coolant to use now that the engine is basically spotless? Dexcool Extended? or Peak Global?, I hear the latter is better, I am religious about oil changes and my Silverado Dually 8.1 gets its Mobil 1 swapped out every 1500 miles. And Amsoil is liquid gold up here and nigh impossible to find cheap.
Thanks.
Thanks.
